Какая там штатная размерность?
__________________
Не знаю по-этому и спрашиваю
195/65R14 встанут.
__________________
вот то, что в своё время мне давал Денис
я свой выбор остановил на размерности 195х55х15 - ИМХО идеальный вариант, как внешне, так и с точки зрения подвески ... НО ... вот, к примеру Фантом и 17 ставил на 40 профиле ... выбор за вами !P10 tire fitments:
185/60/14 - 22.7" diameter (35-45mm offset required)
185/65/14 - 23.5" diameter (35-45mm offset required)
195/55/14 - 22.4" diameter (38-45mm offset required)
*195/60/14 - 23.2" diameter (35-45mm offset required)*(91-93 P10)
*195/65/14 - 24" diameter (35-45mm offset required)*(93.5-96 P10)
205/60/14 - 23.7" diameter (38-42mm offset required)
195/50/15 - 22.7" diameter (35-45mm offset required)
195/55/15 - 23.4" diameter (35-42mm offset required)
195/60/15 - 24.2" diameter (35-38mm offset required)
205/50/15 - 23.1" diameter (38-42mm offset required)
205/55/15 - 23.9" diameter (38mm offset required)
195/50/16 - 23.7" diameter (35-42mm offset required)
205/40/16 - 22.5" diameter (38-45mm offset required)
205/45/16 - 23.3" diameter (38-42mm offset required)
205/50/16 - 24.1" diameter (38-40mm offset required)
215/40/16 - 22.8" diameter (40-42mm offset required)
215/45/16 - 23.6" diameter (40mm offset required w/ 7.5" rims...40-42mm w/ 7" rims) correction
205/40/17 - 23.5" diameter (38-40mm offset required)
205/45/17 - 24.3" diameter (38mm offset required)
215/40/17 - 23.8" diameter (40mm offset required w/ 7.5" rims...40-42mm w/ 7" rims)
215/35/18 - 23.9" diameter (40mm offset required w/ 7.5" rims...40-42mm w/ 7" rims)
*stock setup
Note on P10 offsets & sizes available- All offsets listed assuming the car is not lowered more than 3"... otherwise, fender lip trimming may be required... some other sizes & alternate offsets are known to fit a P10 with the use of spacers, and/or trimming the fender lips.
Example of sizes known to fit P10 w/ clearance modifications:
225/40/16(40mm offset)
215/35/19(40mm offset)
Wheel width ranges that will work with all tires listed above:
14x6-14x7
15x6-15x7
16x6.5-16x7.5
17x7-17x8
18x7-18x8
19x7-19x8
